hi,
like others on this forum. I’m having problem with ntp updates. Router is CCR-1036, tested on 6.24, 6.27. Tried so many servers but update not happening.
anyone can shed some light on this problem
thanks
hi,
thanks
NTP Package is installed?
What NTP servers you try to use?
You put inside the name or the ip?
tried with or without ntp package. Servers were domain names and were resolved properly.
Сonfirm the problem.
NTP client does not work on version 6.25.
NTP package installed.
