NTP packets not getting through, v6.13
Hardware: RB2011UAS-2HnD
Software: v6.13
I’ve been using the internal SNTP client, as well as two other devices on my network, for some time now and never had issues with it. However, I recently upgraded to v6.13 and now none of the SNTP or NTP clients work. I can see packets coming in from the LAN, however they do not get sent out into the WAN as far as I can tell.
Running torch on the WAN interface, I cannot see NTP requests going out, however I can see the NTP responses coming back. The connection tracker shows the attempt as Unreplied, even when I can see the packets arriving. I have tried allowing all NTP packets in the firewall, but that did not have any effect.
The firewall/NAT configuration should be pretty standard for a home router. Here is the config:
add arp=proxy-arp l2mtu=1598 name=bridge_lan
set [ find default-name=ether1 ] name=ether1_Syx
set [ find default-name=ether4 ] advertise=1000M-full name=ether4_OmniOS
rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether7 ] name=ether7_WDTV
set [ find default-name=ether10 ] name=ether10_CableModem
set [ find default-name=sfp1 ] disabled=yes speed=100Mbps
/ip neighbor discovery
set ether10_CableModem discover=no
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode
band=2ghz-onlyn basic-rates-a/g=“” basic-rates-b=11Mbps channel-width=
20/40mhz-ht-below country=“united states” disabled=no distance=indoors
frequency=2462 l2mtu=2290 mode=ap-bridge rate-set=configured
security-profile=Styx ssid=styx supported-rates-a/g=
12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=11Mbps
wireless-protocol=802.11 wmm-support=enabled
set wlan1 discover=no
add name=pool_lan ranges=192.168.88.10-192.168.88.254
add add-arp=yes address-pool=pool_lan disabled=no interface=bridge_lan
lease-time=1w name=dhcp_server_lan
/port
set 0 name=serial0
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge_lan interface=ether5
add bridge=bridge_lan interface=ether6
add bridge=bridge_lan interface=ether7_WDTV
add bridge=bridge_lan interface=ether8
add bridge=bridge_lan interface=ether9
add bridge=bridge_lan external-fdb=yes interface=wlan1
add bridge=bridge_lan interface=ether1_Syx
add bridge=bridge_lan interface=ether2
add bridge=bridge_lan interface=ether3
add bridge=bridge_lan interface=ether4_OmniOS
add address=192.168.88.1/24 interface=bridge_lan network=192.168.88.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=ether10_CableModem
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
set udp-timeout=20s
/ip settings
set tcp-syncookies=yes
add chain=input comment=ICMP limit=2,5 protocol=icmp
add action=log chain=input comment=NTP disabled=yes log-prefix=“NTP IN” port=123 protocol=udp
add action=log chain=forward comment=NTP disabled=yes log-prefix=“NTP FWD” port=123 protocol=udp
add chain=input comment=“Established Connections” connection-state=established
add chain=input comment=“Related Connections” connection-state=related
add action=drop chain=input comment=“Drop invalid connections” connection-state=invalid
add chain=forward comment=“UPnP Connections” disabled=yes dst-address=192.168.88.0/24
add chain=input comment=“L2TP Incoming” connection-state=new dst-port=
500,1701,4500 in-interface=ether10_CableModem protocol=udp
add chain=input comment=“PPTP Incoming” connection-state=new dst-port=1723
in-interface=ether10_CableModem protocol=tcp
add action=log chain=input comment=“Log everything else” disabled=yes
log-prefix=“DROP INPUT”
add action=drop chain=input comment=“Drop everything else” in-interface=
ether10_CableModem
add action=masquerade chain=srcnat out-interface=ether10_CableModem
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set allow-disable-external-interface=no enabled=yes
/ip upnp interfaces
add interface=ether10_CableModem type=external
add interface=bridge_lan type=internal
/system clock
set time-zone-name=America/Puerto_Rico
/system identity
set name=Styx
/system ntp client
set enabled=yes mode=unicast primary-ntp=162.243.72.74 secondary-ntp=173.230.144.109Any help with this will be greatly appreciated. Thanks!
EDIT: Forgot to say. Previous version was 6.9. I did downgrade to that version again but NTP did not start working. I also did a routerboard upgrade, however I don’t know if this would cause the problem.
