NTP question
can i limit what clients are allowed to access my local NTP server
would this work. ? or is there a better way to limit NTP traffic.
just dont want anyone using our main router except our clients.
add protocol=udp src-port=123 action=accept src-address=(client ip address) chain=input
then drop everything else
add protocol=udp src-port=123 action=drop
If your clients come through internal interfaces, it would probably be easier to drop requests from the external interface instead of adding all those other rules.
some of our clients are on the outside of our network so we could i guess just add those who are on the outside
If you end up with fewer rules, it’s worth it.
