I’m trying to get the ntp server running under 5.5. It is installed and
running but will not respond to queries. The router has 3 LAN and one WAN
interface; no luck on any of them. The standard ntp client on the router is
configured and synced with an “outside” server. Tried the src-nat “trick” mentioned elsewhere
on the forum; didn’t make any difference at all. Has anyone been able to sucessfully
run an ntp server on RouterOS 5.5?
I just set up a test system with my spare router and installed 5.24 along with the ntp package.
Still no luck; it is exhibiting the same behaviour as the other system. Is there additional
documentation for the ntp server? On a system with multiple interfaces, (and say a linux-based
ntp), there are usually configuration options to set which interfaces the server listens/responds to.
