NTP Server in Ver 3
Can anyone tell me were in version 3 the NTP server has moved to. I have looked high and low but it seems to be missing.
thanks
Erik
/system ntp
You have to install the NTP package that is included in the all-packages zip file.. It is not part of the single file..
-Gerard
Thanks… didn’t think to look in the “separate” packages… Just assumed the combined had all the files.
Erik
