ntp server missing after os upgrade
Hi, my RB333 was just upgraded from 3.27 to 4.5, now I don’t have an ntp server any more. The client is still there and working fine.
I re-downloaded the 4.5 zip file, unzipped it and tried to upload ntp-4.5-ppc.npk, but got the error “Could not change the key- invalid key”.
A look at my license shows Upgradeable to 5.x, level 4, and when I click the Update License Key button, it says “License key is up to date!”
Any suggestions as to where to go from here?
Ken, vk7krj
http://www.vk7krj.com
you tried to upload it to packages folder, you need to upload it to FILES folder. then it will work
Thanks Normis, it works a treat when I stop being dumb! Now I am back to an ntp server as well as client.
Ken, vk7krj
www.vk7krj.com
