NTP stops
ntp client stops in routeros6.9
downgrade to 6.7 ntp works fine
This with routerboard rb2011-UAS-RM
But did you notice, that the time is synchronised? It works, it just shows stopped until you reboot. I think this bug is cosmetic.
Hey Normis, after reboot works NTP
Thanks for your quick reply
It works even before reboot, but it only shows Stopped by mistake.
