RC13
NTP client is configured as follows:
/system ntp client
set enabled=yes mode=unicast primary-ntp=212.23.8.6 secondary-ntp=0.0.0.0
However, in the firewall log I’m seeing this continually:
Dec 21 10:54:56 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.65.1:123, len 76
Dec 21 10:55:09 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.40.1:123, len 76
Dec 21 10:56:01 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.65.1:123, len 76
Dec 21 10:56:13 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.40.1:123, len 76
Dec 21 10:57:07 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.65.1:123, len 76
Dec 21 10:57:18 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.40.1:123, len 76
Dec 21 10:58:11 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.65.1:123, len 76
Dec 21 10:58:22 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.40.1:123, len 76
Dec 21 10:59:17 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.65.1:123, len 76
Dec 21 10:59:25 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.40.1:123, len 76
Dec 21 11:00:24 net4501 firewall,info Output output: in:(none) out:Internet, proto UDP, xxx.11.xxx.xxx:123->192.168.65.1:123, len 76
Curious thing is; I don’t have 192.168.40.1 or 192.168.65.1 configured anywhere.
Regards
Andrew
