ntstreme on of script help
Hello, i saw a script for checking if client is associated on ap, if not script tries nstreme parameters and turn it on for connecting to nstreme AP.
Can some one help me write that, I dont know how to do scripting.
http://forum.mikrotik.com/t/voip-over-nstreme-ptmp-not-working-good/25884/9
here is a link to a script that might do what you want. I works great and you can just cut and past to a terminal session. If the client looses connection it will try 20,10,5 mhz channels with and with out Nstreme.
thank you, I was looking for that thread couldnt find it, used search :slight_smile:/
