Dear Community Members,
I have a question - that someone here may know the answer to.
Can a MMCX male connect with U.fl female and vice versa.
The technical issue I am tackling is that a mini PCI WLAN card’s connectors are located differently and I need to extend the cable bearing U.Fl connector. Basically - I need a U.fl male to female extension. However what I am finding in reasonable price is an MMCX male to female and hence the question.
Thanks for reading this far.
This is the connector I am finding no the U.fl so maybe I can use this.
