NUC connects with hAP lite via Swith only. w/o switch: no link. MDIX-problem?
I have a hAP lite in bridge mode connected with two PCs and an upsteam router. An Intel NUC NUC8i5BEH works only if connected via Switch. If I connect NUC directly to hAP the cable test shows “no link”. Looks like auto sensing / MDIX problem. As soon as I connect a switch in between it works. How can I check which end causes the issue?
[admin@MikroTik_hAP_lite] > /interface ethernet monitor ether4
                    status: no-link
          auto-negotiation: done
               advertising: 10M-half,10M-full,100M-half,100M-full
  link-partner-advertising:
                    status: no-link
full config is attached.
hap_connect_problem_1.rsc (24.3 KB)
