Number of connections?
Hi everyone!
Who knows whether it’s possible (with SNMP?) to poll a Mikrotik unit and find the total number of connections (/ip firewall connections ) this way?
It isn’t possible.
I see 2 ways
  1. a script on the mikrotik, it send an email each time you want this data
  2. from a remote server execute a script with telnet and retreive the info
#2 sounds good! That I should be able to do from the same server that would have done the SNMP-fetch anyway… :wink:
Do you have an example of such a script for me/us? :slight_smile:
A simple expect script may look like this:
#!/usr/bin/expect
#Information gathering script for RouterOS
# this will timeout the script if something go wrong
set timeout 20
# set these variables for your network
set router "1.1.1.2"
set logn "admin"
set passwd ""
set rta_prompt ".* >"
# Setting loglevel 0 to avoid spamming from router
log_user 0
# Spawning quiet telnet session
eval spawn -noecho telnet "$router"
# Authentication stuff
expect "Login:" {send "$logn\r"}
expect "Password:" {send "$passwd\r"}
# Retrieve and print info about connections
expect "$rta_prompt" {
  send "/ip firewall connection print\r"
  set aa $expect_out(buffer);
  send_user "\n-------------------------------\n";
  send_user $aa;
sleep 2
send "\r"
Note that you must have TCL and Expect installed in order to get this script work. And I guess this should be *nix machine:)
I tried the script on my *nux machine, and it doesn’t seem to generate any output, or so it seems…?
Do you have expect and tcl installed? telnet enabled on router?
this code works perfectly for me! good job Eugene! :wink:
Yup, expect 5.37.1 & tcl 8.4.6 are present. Commenting out the log_user parameter does give the right(?) output, with
-- [Q quit|D dump|down]
on the bottom line.
He, he:) you have too much connections in your table. Do not comment out log_user parameter. Add without-paging argument to /ip firewall connection print command instead.
Eugene
That gives more! :slight_smile:
123:80    tcp  time-wait   1m41s
152  A 192.168.24.140:58533  199.181.132.206:80    tcp  time-wait   1m23s
153  A 192.168.24.140:58531  199.181.132.207:80    tcp  time-wait   1m23s
154  A 192.168.24.140:58536  199.181.132.207:80    tcp  time-wait   1m23s
155  A 192.168.24.140:47582  204.74.101.1:53       udp              2m47s
156  A 192.168.24.140:55077  204.152.184.184:6277  tcp  established 4d23h54m2s
157  A 192.168.24.140:58496  206.16.0.222:80       tcp  time-wait   19s
158  A 192.168.24.140:58518  206.16.0.222:80       tcp  time-wait   1m23s
159  A 192.168.24.140:58576  207.171.166.48:80     tcp  time-wait   1m44s
160  A 192.168.24.140:58577  207.171.166.48:80     tcp  time-wait   1m44s
161  A 192.168.24.140:58578  207.171.166.48:80     tcp  time-wait   1m48s
162    192.168.24.140:47582  207.171.169.7:53      udp              13s
163  A 192.168.24.140:56123  212.97.129.35:6277    tcp  established 4d23h59m57s
164  A 192.168.24.140:58575  213.84.23.119:80      tcp  fin-wait    1m42s
165 U  192.168.24.140:58517  213.220.100.3:80      tcp  syn-sent    1m55s
166  A 192.168.24.140:58520  213.220.100.3:80      tcp  time-wait   1m58s
167    192.168.24.140:47582  216.200.69.14:53      udp              24s
168  A 192.168.24.140:47582  216.239.120.69:53     udp              2m11s
169  A 195.225.3.19:64413    213.151.155.141:6277  tcp  established 4d40m19s
170  A 204.152.184.184:58374 213.151.152.215:6277  tcp  established 4d23h59m57s
171  A 204.152.184.184:56980 213.151.155.141:6277  tcp  established 4d41m48s
172  A 212.4.33.214:13095    213.151.155.141:80    tcp  established 2d23h57m59s
173  A 213.151.152.215:1499  205.188.8.136:5190    tcp  established 4d23h59m39s
174  A 213.151.152.215:1492  205.188.11.184:5190   tcp  established 4d23h59m7s
175  A 213.151.152.215:1483  207.46.107.167:1863   tcp  established 4d23h59m40s
176  A 213.151.152.215:1488  207.46.107.169:1863   tcp  established 4d23h59m39s
177  A 213.151.152.215:1496  216.155.193.184:5050  tcp  established 4d23h59m6s
178  A 213.151.152.215:1480  217.13.3.82:1723      tcp  established 4d5h42m3s
179  A 213.151.152.215       217.13.3.82           gre              4d23h59m59s
180    213.151.153.79:1026   213.151.152.215:137   udp              2s
181  A 213.151.155.141:1319  205.188.8.138:5190    tcp  established 4d21m18s
182  A 213.151.155.141:1321  205.188.11.184:5190   tcp  established 4d21m18s
183  A 213.151.155.141:1240  207.46.106.71:1863    tcp  established 4d21m18s
184  A 213.151.155.141:1241  207.46.107.62:1863    tcp  established 4d21m18s
185  A 213.151.155.141:1248  208.245.212.67:5222   tcp  established 4d21m18s
186  A 213.151.155.141:1213  216.155.193.178:5050  tcp  established 4d21m22s
187  A 213.151.155.141:1479  217.13.2.82:1723      tcp  established 4d19m53s
188  A 213.151.155.141       217.13.3.82           gre              4d21m30s
[evert@MEULIE] >
But what I actually need is just the # of connections, as a single number… :wink:
Revised version of the script to use with ssh. The script assumes you have no password for the account specified. Uncomment authentication line if you actually have a password.
Paging issues are fixed too
#!/usr/bin/expect
#Information gathering script for RouterOS v1.2
set timeout 20
set logn "admin"
set passwd ""
log_user 0
# Spawning quiet ssh session
eval spawn -noecho ssh -l "$logn" "$router"
#expect ".*password:" {send "$passwd\r"}
#set maximum buffer length (there are too many connections sometimes)
match_max 50000
  send "/ip firewall connection print without-paging\r"
  send_user $aa;
sleep 2
send "\r"
I expected this :slight_smile:
$ wc -l < myscript
Maybe this way?:slight_smile:
(myscript is the name of expect script)
EDIT:
Or isuue the /ip firewall connection print command with count-only argument.
This would count the number of lines of the myscript file… :sunglasses:
Hmm, after that change I get no output at all from the script… weird…
Sorry, my mistake. The correct should be:
$ ./myscript | wc -l
And working count-only snippet:
  send "/ip firewall connection print count-only\r"
expect -re "\[0-9]+" {
  set aa $expect_out(0,string);
  send_user "$aa\n";
sleep 1
send "\r"
:smiley: :smiley: Yes! :smiley: :smiley:
As you can see here, that works perfectly! :slight_smile:
I’m impressed;) Can you share MRTG configuration to use script output for the benefit of others? :))
Sure:
Target[conncount]: `/usr/local/bin/connection_poll`
Options[conncount]: gauge,growright,nopercent,noo
Title[conncount]: Connection count
MaxBytes[conncount]: 1000
PageTop[conncount]: <H1>Connection count</H1>
LegendO[conncount]: Connections
LegendI[conncount]: Connections
YLegend[conncount]: connections
ShortLegend[conncount]: &nbsp;connections
It’s as simple as that… :sunglasses:
Hmm, I’m trying to turn it into a SSH-enabled script, but there seems to be something not quite right with my version:
#!/usr/bin/expect
set timeout 20
set router "1.2.3.4"
set logn "mrtg"
set passwd "blah"
log_user 0
eval spawn -noecho ssh "$logn@$router"
      send_user "$aa\n0\n";
      sleep 1
      send "\r"
This script takes 40 seconds to finish, and always returns 192 as value… :question:
