I’m using btest with a CCR1036-12G-4S (36 core CPU). I’m using UDP to do throughput tests and in system → resources → CPU window I’m seeing that only one CPU reaches high values. I believe that this could be limiting the throughput, with only one PC connect directly it is reaching a max of 450 Mbps.
I just upgrade the mikroitk and I need to perform the test with 2 PC, before the upgrade I did the test and one of the CPUs was reaching the 100% at 600 Mbps, 300 Mbps in each PC connected directly to different boards.
I’m opening several btest windows and creating flows of 250 Mbps. Is there any way that dynamically assign more than one CPU and probably reach higher throughput values?
Thanks and regards,
hcalex
