number range
Is there a way to add / set / edit a command to a number range using the cli?
With the introduction of 24/48 port switches this is now needed more than before.
Say I want to add 36 ports or perhaps an arbitrary range of ports like 0-12, 15, 17, 20-35 to vlan 101
Doing
/interface bridge port set 0,1,2,3..etc..etc..34,35 pvid=101
is just not practical.
it would be nice to be able to do.
/interface bridge port set 0-35 pvid=101
or
/interface bridge port set 0-12,15,17,20-35 pvid=101
I found this:
https://wiki.mikrotik.com/wiki/Using_scripting_to_overcome_the_inability_to_specify_number_ranges_on_the_command_line
Which is a cut and paste work around for a range but it’s still not ideal
There is a shorter command:
:for i from=0 to=12 do={/interface bridge port set $i pvid=101}
Thanks. that is very helpful.
Having the cli accept ranges would be a nice addition though
