Hi !
I’m missing the feature of virtual APs together with NV2. Usually, I have one general SSID on a sender, where customers can roam between if one segment fails, for additiona redundancy.
Some customers usually will connect to the weaker signal for unknown reason, I do connect these to a sector specific SSID which is realised by Virtual AP.
Also, sharing a cell tower & APs with another provider needs Virtual APs for splitted IP connectivities.
I wouldn’t need this functionality, if clients would do some type of “background scan” therefore always selecting the strongest signal even when connected to a weaker one.
NV2 is a huge improvment in crowded sectors, in throughput and response time - really many thanks for that.
Greetings Maria / WISP in Austria
