we’re experiencing an outstanding disconnection problem between AP and a client; the client dissociates roughly every 30 minutes. We already tried some modifications to the config (eg. increasing tdma period), but without any success at all.
This is the configuration:
AP: RB433AH with a sector
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" arp=enabled band=5ghz-onlyn basic-rates-a/g=6Mbps \
basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz compression=no country=italy default-ap-tx-limit=0 \
default-authentication=no default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no \
disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=5540 frequency-mode=manual-txpower frequency-offset=0 hide-ssid=\
no ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 ht-txchains=0,1 \
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
00:14:6C:65:6F:15 max-station-count=2007 mode=ap-bridge mtu=1500 name=wlan1 noise-floor-threshold=default nv2-cell-radius=15 \
nv2-noise-floor-offset=default nv2-qos=default nv2-queue-count=2 nv2-security=enabled on-fail-retry-time=100ms \
periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
00146C656F15 rate-selection=legacy rate-set=default scan-list=default security-profile=default ssid=alpha station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=3 tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 \
wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic wireless-protocol=nv2 wmm-support=disabled
LOGS:
11:02:31 wireless,info 00:0C:42:88:D6:AB@wlan1: disconnected, not responding
11:02:33 wireless,debug wlan1: 00:0C:42:88:D6:AB in local ACL, accept
11:02:33 wireless,info 00:0C:42:88:D6:AB@wlan1: reconnecting
11:02:34 wireless,info 00:0C:42:88:D6:AB@wlan1: connected
11:36:29 wireless,info 00:0C:42:88:D6:AB@wlan1: disconnected, not responding
11:36:31 wireless,debug wlan1: 00:0C:42:88:D6:AB in local ACL, accept
11:36:31 wireless,info 00:0C:42:88:D6:AB@wlan1: connected
11:57:42 wireless,info 00:0C:42:96:B8:96@wlan1: disconnected, not responding
11:57:52 wireless,debug wlan1: 00:0C:42:96:B8:96 in local ACL, accept
11:57:52 wireless,info 00:0C:42:96:B8:96@wlan1: connected
11:59:45 wireless,info 00:0C:42:88:D6:AB@wlan1: disconnected, not responding
11:59:45 wireless,debug wlan1: 00:0C:42:88:D6:AB in local ACL, accept
11:59:45 wireless,info 00:0C:42:88:D6:AB@wlan1: connected
Client: SXT 5HnD
/interface wireless
bridge-mode=enabled channel-width=20mhz compression=no country=italy default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s distance=\
dynamic frame-lifetime=0 frequency=5600 frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 \
ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any \
00:0C:42:88:D6:AB max-station-count=2007 mode=station mtu=1500 name=wlan1 noise-floor-threshold=default nv2-cell-radius=30 \
000C4288D6AB rate-selection=legacy rate-set=default scan-list=default security-profile=default ssid=alpha station-bridge-clone-mac=\
00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2 tx-power-mode=\
default update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no \
wds-mode=disabled wireless-protocol=nv2 wmm-support=disabled
11:02:28 wireless,info 00:14:6C:65:6F:15@wlan1: lost connection, synchronization timeout
11:02:33 wireless,debug wlan1: must select network
11:02:33 wireless,debug 00:80:48:XX:XX:XX: on 5300 AP: yes SSID xxxxxxx caps 0x431 rates 0xff00 basic 0x100 MT: yes
11:02:33 wireless,debug 00:0C:42:XX:XX:XX: on 5500 AP: no SSID xxxxxxx caps 0x0 rates 0x0 basic 0x0 MT: no
11:02:33 wireless,debug 00:10:E7:XX:XX:XX: on 5520 AP: yes SSID xxxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:02:33 wireless,debug 00:11:22:XX:XX:XX: on 5700 AP: no SSID xxxxxxx caps 0x0 rates 0x0 basic 0x0 MT: no
11:02:33 wireless,debug 00:80:48:XX:XX:XX: on 5540 AP: yes SSID xxxxxxx caps 0x431 rates 0xff00 basic 0x100 MT: yes
11:02:33 wireless,debug 00:14:6C:65:6F:15: on 5540 AP: no SSID alpha caps 0x0 rates 0x0 basic 0x0 MT: no
11:02:34 wireless,info 00:14:6C:65:6F:15@wlan1 established connection on 5540, SSID alpha
11:36:26 wireless,info 00:14:6C:65:6F:15@wlan1: lost connection, synchronization timeout
11:36:31 wireless,debug wlan1: must select network
11:36:31 wireless,debug 00:80:48:XX:XX:XX: on 5300 AP: yes SSID xxxxxx caps 0x431 rates 0xff00 basic 0x100 MT: yes
11:36:31 wireless,debug 00:0C:42:XX:XX:XX: on 5500 AP: no SSID xxxxxx caps 0x0 rates 0x0 basic 0x0 MT: no
11:36:31 wireless,debug 00:10:E7:XX:XX:XX: on 5520 AP: yes SSID xxxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:36:31 wireless,debug 00:11:22:XX:XX:XX: on 5700 AP: no SSID xxxxxx caps 0x0 rates 0x0 basic 0x0 MT: no
11:36:31 wireless,debug 00:14:6C:65:6F:15: on 5540 AP: no SSID alpha caps 0x0 rates 0x0 basic 0x0 MT: no
11:36:31 wireless,debug 00:0C:42:XX:XX:XX: on 5500 AP: no SSID xxxxx caps 0x0 rates 0x0 basic 0x0 MT: no
11:36:31 wireless,debug 00:10:E7:XX:XX:XX: on 5500 AP: yes SSID xxxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:36:31 wireless,debug 00:15:6D:XX:XX:XX: on 5640 AP: yes SSID xxxxxxx caps 0x431 rates 0x3f00 basic 0x100 MT: yes
11:36:31 wireless,debug 00:10:E7:XX:XX:XX: on 5700 AP: yes SSID xxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:36:31 wireless,debug 00:10:E7:XX:XX:XX: on 5700 AP: yes SSID xxxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:36:31 wireless,info 00:14:6C:65:6F:15@wlan1 established connection on 5540, SSID alpha
11:59:40 wireless,info 00:14:6C:65:6F:15@wlan1: lost connection, synchronization timeout
11:59:45 wireless,debug wlan1: must select network
11:59:45 wireless,debug 00:80:48:XX:XX:XX: on 5300 AP: yes SSID xxxxxxx caps 0x431 rates 0xff00 basic 0x100 MT: yes
11:59:45 wireless,debug 00:0C:42:XX:XX:XX: on 5500 AP: no SSID xxxxxx caps 0x0 rates 0x0 basic 0x0 MT: no
11:59:45 wireless,debug 00:10:E7:XX:XX:XX: on 5520 AP: yes SSID xxxxxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:59:45 wireless,debug 00:10:E7:XX:XX:XX: on 5520 AP: yes SSID xxxxxxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:59:45 wireless,debug 00:11:22:XX:XX:XX: on 5700 AP: no SSID xxxxxxx caps 0x0 rates 0x0 basic 0x0 MT: no
11:59:45 wireless,debug 00:14:6C:65:6F:15: on 5540 AP: no SSID alpha caps 0x0 rates 0x0 basic 0x0 MT: no
11:59:45 wireless,debug 00:10:E7:XX:XX:XX: on 5700 AP: yes SSID xxxxxxxx caps 0x1 rates 0xff00 basic 0x100 MT: no
11:59:45 wireless,debug 00:80:48:XX:XX:XX: on 5540 AP: yes SSID xxxxxxx caps 0x431 rates 0xff00 basic 0x100 MT: yes
11:59:45 wireless,debug 00:80:48:XX:XX:XX: on 5580 AP: yes SSID xxxxxxxx caps 0x431 rates 0xff00 basic 0x100 MT: yes
11:59:45 wireless,info 00:14:6C:65:6F:15@wlan1 established connection on 5540, SSID alpha
nv2-security is enabled (we tried without it, too), and access point has been added to client’s connect list.
Any hints?
Regards,
Simone
