Nv2 High jitter and latency 'ping times'?
As you all know Nv2 TDMA based protocol has much higher ping rates then it’s predecessor Nstreme..
Will there be any optimizations for Nv2 protocol or any upgrades for higher bandwith and 802.11N usage in Nstreme protocol?
Nv2 great for ptmp links but if you want to use it for transporting your 150Mbps backhaul to 3 hops away it gives you latency around 100-150 ms at client side, this will cause Tcp window overflow and reduced bandwith.. if you use nstreme in your backhoul, you will get 10ms with 30-35 Mbps bandwith on same link..
Is any body working on this issues in mikrotik?
I had the below latency with NV2 and with 2 links. One ~18km and the second one ~25km.
Now I get beter latency than the photo with the ROS 6.1.
