NV2-nstreme DUAL
Is there any chance MT could implement the old nstreme dual action for use with the nv2-nstreme protocol suite? Also the synchronisation between NV2 AP’s would be good, dont know if that’s any easier or more predictable if you were to be dealing with true full-duplex transmissions. perhaps the AP’s could be simply synced with NTP?
I would really love NV2-nstreme DUAL. and perhaps you should look at Adrian Chadd’s FreeBSD Atheros 802.11n TDMA implementation. It doesn’t use CSMA/CA and it yields an almost 100% increase in throughput over CSMA/CA. something which you are failing to do here, perhaps there is something to be considered? of course tdma traffic is going to go better is there is time synchronisation between nodes as well, but yeah. PLEASE, nv2-nstreme DUAL!
