Ive got an Tower on a mountain, where Ive got 2 links One is 60Km Using NV2
The other link is 28Km Using Nstreme
As soon as The second link is Nstreme - My RX Quality of the 60Km Link drops from 99 to 49 Instantly, and throuhput Halves. When I Disable the Nstreme on the second link, the throughput Jumps back up, and the link is perfect..
I am using Ubiquity Dishes On all my links, with Dual Chains
Both Links are on 1 RB433uah Using Mikrotik R52Hn. Why is this interference?
As Nv2 does not use CSMA technology it may disturb any other network in the same channel. In the same way other networks may disturb Nv2 network, because every other signal is considered noise.
Perhaps you should look at the frequency separation of your nstreme and NV2 channels.
In the same tower you need at least 2 or more meters of vertical distance between the dishes… and how say here, more than 200Mhz of channel separation.
