nv2 on x86 platforms
Hello all. Tell me please, whether nv2 on platforms x86 in version 6 ROS.
In advance thank you all for your answers.
I think NV2 for x86 never came out…
Unfortunately this fact not very reassuring…
Performance platforms mipsbe very far from the performance of the same Intel Atom.
since Nv2 relies on hardware accuracy for some features, we can’t do the same in x86, because every device is different. so the result is not so good as in RouterBOARD.
So just to be clear
A) it doesn’t work
or
B) “result is not so good as in RouterBOARD”
B)
Nv2 is available on x86, you can try it. But we don’t guarantee any good results. Maybe if you are lucky
Response on this issue has received, thank you.
Normis, tell me, is it possible to “bleed” through Mikrotik PTP link 300 + Mbps on a platform 411GL+R52Hn and license extrachanell?
Thank you in advance.
