NV2 Problem
I have been running ospf successfully for some time now, And recently I thought I would give NV2 a shot and see how it would do in a PTP application. Its an existing PTP running RB411AH on each side and R52hn cards. I have been using nstreme with no issues at all. but after I change the AP to NV2 and the Slave re registers I cant route to anything on the other side of this PTP bridge. The radios are setup as: ap bridge and station pseudobridge. Is there anything obvious that I have to change for this to work?
Thanks,
Josh
The table here clarifies your issue:
http://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes#Applicability_Matrix
Pseudobridge is not compatible with Nv2, use Stration Bridge instead. It will also work better than Pseudobridge.
also please upgrade to RouterOS v5.9 where we have Nv2 improvements for links that have interference.
Thanks Normis! Your support rocks!
Regards,
Josh
