Greetings…
I have a mANTBox 15s as my AP Bridge and Qty 5 SXT5ac’s as my Station Bridges… I am using NV2, configs on all 5 SXT5ac’s are identical… Yet I am only able to “See” the LAN side from two of them… The SXT5ac’s are plugged into a 24-port CRS Switch… If I physically connect to the switch and run Winbox I can see the devices that are plugged into the switch only (ie. a couple RBcAP’s, the CRS, and the SXT5ac…) I am unable to see the rest of the network (mANTBox 15s and other SXT5ac’s)… However, if I plug the LAN cable running from the SXT5ac directly to my laptop - I can see everything from the MantBox and operational SXT’s… Am I missing something here?
Many Thanks for a quick explanation/solution
Spooner
