NV2 Qos set priority
Hi All
I am wondering if I understand the QOS on NV2 correctly. According to what I have read you can set priority with mangle and then select the queue count in the NV2 tab. Can you then do something like this below? Would it be beneficial to do basic QOS on the NV2 side or rather do this normally with a queue tree. Note this would be on the actual tower AP with v6.2 /queue count = 8 / Qos = default
Would this work?
/ip firewall mangle
add action=set-priority chain=forward comment="NV2 prority queue (mark everyting)" new-priority=7
add action=set-priority chain=forward comment="NV2 prority queue (icmp)" protocol=icmp
add action=set-priority chain=forward comment="NV2 prority queue (winbox)" dst-port=8291 protocol=tcp
add action=set-priority chain=forward comment="NV2 prority queue (dns)" dst-port=53 new-priority=1 protocol=udp
add action=set-priority chain=forward comment="NV2 prority queue (dns)" dst-port=53 new-priority=1 protocol=tcp
add action=set-priority chain=forward comment="NV2 prority queue (udp)" new-priority=2 protocol=udp
add action=set-priority chain=forward comment="NV2 prority queue (https)" dst-port=443 new-priority=3 protocol=tcp
add action=set-priority chain=forward comment="NV2 prority queue (rdp)" dst-port=3389 new-priority=3 protocol=tcp
add action=set-priority chain=forward comment="NV2 prority queue (www)" dst-port=80 new-priority=4 protocol=tcp
add action=set-priority chain=forward comment="NV2 prority queue (pop)" dst-port=110 new-priority=5 protocol=tcp
add action=set-priority chain=forward comment="NV2 prority queue (smtp)" dst-port=25 new-priority=6 protocol=tcp
add action=set-priority chain=forward comment="NV2 prority queue (p2p)" new-priority=7 p2p=all-p2p
