my AP side wireless export
[admin@U-BRG] > interface wireless print advanced
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:6F:03:2B arp=enabled disable-running-check=no interface-type=Atheros AR9300 radio-name="000C426F032B" mode=bridge
ssid="WAVE" area="" frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5260 band=5ghz-a/n channel-width=20/40mhz-ht-above
scan-list=default wireless-protocol=nv2 rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps
max-station-count=2007 distance=dynamic tx-power=17 tx-power-mode=all-rates-fixed noise-floor-threshold=default nv2-noise-floor-offset=default
periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-
22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-period-size=1
nv2-queue-count=2 nv2-qos=default nv2-cell-radius=10 nv2-security=enabled nv2-preshared-key="grandmaster" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced multicast-helper=default
multicast-buffering=enabled
my Client side wireless export
[admin@U-CLNT] > interface wireless print advanced
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:DF:E9:2A arp=enabled disable-running-check=no interface-type=Atheros AR9300 radio-name="000C42DFE92A" mode=station-bridge
scan-list=default wireless-protocol=nv2-nstreme-802.11 rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic tx-power=17 tx-power-mode=all-rates-fixed noise-floor-threshold=default nv2-noise-floor-offset=default
22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-period-size=2
nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=enabled nv2-preshared-key="grandmaster" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none
