NV2 Sync
Can somebody at Mikrotik please confirm:
As I understand it the APs have to either have GPS, or be on the same subnet, or both, in order to sync.
If GPS is required then I would have to assume that a USB GPS device needs to be added.
If neither is necessary, then please explain how they can magically sync…
Thanks,
Todd
Quote!!!
+1 :slight_smile:
I haven’t tested it, but isn’t this done over the air?
No gps sync only sync radio master with radio slaves on the same channel. The collocation interference isuue is not resolved
What happens to a slave on DFS, when a master on DFS must change channels or vice versa?
does the slave get hung out to dry??
