Hello Guys I put up a link between two devices using the Protocol NV2 then maybe with a bit of calm will also pass some
screenshot of the tests currently being fitted in RX 40Mbps and 37Mbps in some Both UDP RX I was wondering if you can give me some advice for optimize the protocol as working on the menu HT, or the date rate, or the Policy Frame not know I’ve seen on various forums and recommend some settings to optimize your website.
on p2p there is not much to optimize on the nv2 side except that the cell raduis is set in KM, the other setting is for Latency VS thru put as you might have guessed, Just as a concept, Putting up a link between 2 devices has very little value,
If you had to say put a P2P link with Identical devices, RB433AH with Single Pole Antena’s over a 10KM area, with pure line of sight, Using R52Hn cards.
