Is Mikrotik working in nv3? Nv2 is not enought…
Are you talking about the nv2 wireless protocol???
If yes, there is no nv3…
nv3 is a symbolic name for an important wireless improvement. in n nv2 it gives more speed than in ac
So what would you expect in such a fantasy protocol, what are your wishes?
I only expect a protocol capable of competing with the rest of the manufacturers and that is superior to the N protocol
Are you talking about another proprietary point to point protocol exclusive for MikroTik outdoor links?
Why ?
I speak of a protocol tdma / ofdma adapted to the needs dw today: video games, streaming etc etc … in addition to useful tools such as spectral scanning. The nv2 is fine but needs a tuning capable of getting higher speeds and achieve greater stability. Before I was above the wisp who work with ubnt today they take advantage of me.
There is spectral scanning…
What speeds are you trying to achieve…?
The stability is fine to me…
70 megabytes is enough for you in 20 mhz ac?
No, because you cant achieve a better speed it doesnt mean its the protocols fault.
Most likely there is something wrong with your configuration…
With 802.11ac you can easily get 500-600mbits without even trying too hard.
Nv3 will not help your games, because nv2 it is for mikrotik devices only.
nv2 does not lose packages and improves the online game. I would like to know the correct configuration so that a mantbox19s ac get 500-600 megabytes easy in 20 mhz with nv2
Why are you insisting on using 20MHz and Nv2? Just try modern protocols
Did you try changing your frequency?
Also higher the channel width then greater the speed is.. Did you try with 40Mhz Channel width?
What is the distance of your p2p link?
Any obstacles?
What is the values of Tx/Rx on your station’s registration table? CCQ value?
There are so many factors that can affect the quality of your link…
give me an example of configuration with mantbox19s ac without loss of packages with new Normis protocols please. Since I have 20 mhz free there are many interferences.
Did you search in the wiki? There are a lot of examples there.
please share what is the best configuration of the wiki I try it this afternoon and share results in the forum
There is no perfect example, each situation requires adjustments, based on circumstances. I suggest to hire a local consultant who can check how to improve your setup, or you can attend a MTCWE training class.
In an interfered environment, which is the best Normis protocol?
Nothing is perfect in interference conditions. Change frequency to a better one.
