I have a switch that is tagging traffic from an AP to VLAN 23 through ether1 (trunk port) to my MikroTik. When I create a VLAN 23 on ether3 (e3v23) and install the gateway IP on the e3v23 interface everything is peachy-keen. I can then create a bridge (br-v23) and add the e3v23 interface to the bridge… pings begin failing. If I move the IP address to the br-v23 interface it still fails. I tried disabling the bridge and re-enabling in case the arp table needs a jump start or something. Any advice?
By the way, I can add the ether3 interface to the bridge then create the VLAN with tag 23 & interface br-23 but this causes all traffic on ether3 to be part of the bridge. I wanted to bridge the VLAN traffic together on the router. It looks like I have to do more of the VLAN control on the switch… unless one of you have a magic answer…
I am was using 6.30.2 on a CCR… Just noticed the new 6.31 and upgrading to that didn’t fix anything.
Another note… I am for testing purposes just adding a bridge and adding one port member (the VLAN interface).
