Odd problem with DNS and VLANs
Hi all,
I’m setting up a new network in my home using Hap Ax2 routers to provide wired and wireless networking across four VLANs:
VLAN 11 - Main network for the family
VLAN 12 - Guest network
VLAN 13 - IOT network
VLAN 99 - Management network
If I connect to VLAN 11 or 99 everything is great (I haven’t tried this on 13 as it is not supposed to get to the WAN anyway), I can surf the web etc. with no issues. However, VLAN 12 cannot resolve any DNS entries. I can’t see anything getting caught in the firewall, and I think the bridging is set in the same manner for the VLANs. Looking at a capture of the VLAN 12 traffic I note that if the router responds it takes a long time to do it, and when it does the IP packet identifier is always zero - this is not the case on the other VLANs.
Can anyone see what’s going wrong in my configuration please?
# 2024-11-04 07:10:00 by RouterOS 7.16.1
# software id = 276N-QS8G
# model = C52iG-5HaxD2HaxD
# serial number = ****
add admin-mac=78:9A:18:F0:6B:CB auto-mac=no comment=defconf fast-forward=no \
    name=bridge vlan-filtering=yes
/interface vlan
add comment="VLAN 12" interface=bridge name=GuestVLAN vlan-id=12
add comment="VLAN 13" interface=bridge name=IOTVLAN vlan-id=13
add comment="VLAN 11" interface=bridge name=MainVLAN vlan-id=11
add comment="VLAN 99" interface=bridge name=ManagementVLAN vlan-id=99
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add band=2ghz-ax disabled=no name="2G AX"
add band=5ghz-ax disabled=no frequency=5260-5380 name="5G AX" \
    skip-dfs-channels=10min-cac width=20/40/80mhz
/interface wifi
set [ find default-name=wifi2 ] channel="2G AX" configuration.antenna-gain=0 \
    .country="United Kingdom" .mode=ap .ssid=MikroTik-F06BCF disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel="5G AX" configuration.country=\
    "United Kingdom" .mode=ap .ssid=MikroTik-F06BCF disabled=no mtu=1500 \
    name=wifi_5 security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
    .ft-over-ds=yes
/interface wifi datapath
add bridge=bridge disabled=no name=Main vlan-id=11
add bridge=bridge disabled=no name=Guest vlan-id=12
add bridge=bridge disabled=no name=IOT vlan-id=13
add bridge=bridge disabled=no name=Manager vlan-id=99
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=Main
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=Guest
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=IOT
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=Management
/interface wifi configuration
add channel="5G AX" country="United Kingdom" datapath=Main disabled=no mode=\
    ap name=Main_5 security=Main ssid=ComingSoon
add channel="5G AX" country="United Kingdom" datapath=IOT disabled=no \
    hide-ssid=yes mode=ap name=IOT_5 security=IOT ssid=Devices
add channel="5G AX" country="United Kingdom" datapath=Guest disabled=no mode=\
    ap name=Guest_5 security=Guest ssid=MostWelcomeGuests
add channel="2G AX" country="United Kingdom" datapath=Manager disabled=no \
    hide-ssid=yes name=Management security=Management \
    security.authentication-types=wpa2-psk,wpa3-psk ssid=Manager
add channel="2G AX" country="United Kingdom" datapath=Main disabled=no mode=\
    ap name=Main_2 security=Main ssid=ComingSoon
add channel="2G AX" country="United Kingdom" datapath=Guest disabled=no mode=\
    ap name=Guest_2 security=Guest ssid=MostWelcomeGuests
add channel="2G AX" country="United Kingdom" datapath=IOT disabled=no \
    hide-ssid=yes mode=ap name=IOT_2 security=IOT ssid=Devices
/interface wifi
add channel.frequency=5260-5380 configuration=Guest_2 configuration.mode=ap \
    disabled=no mac-address=7A:9A:18:F0:6B:D1 master-interface=wifi2 name=\
    Guest_2
add channel.frequency=5260-5380 configuration=Guest_5 configuration.mode=ap \
    disabled=no mac-address=7A:9A:18:F0:6B:D3 master-interface=wifi_5 name=\
    Guest_5
add channel.frequency=5260-5380 configuration=IOT_5 configuration.mode=ap \
    datapath=IOT disabled=no mac-address=7A:9A:18:F0:6B:D0 master-interface=\
    wifi2 name=IOT_2 security=IOT
    datapath=IOT disabled=no mac-address=7A:9A:18:F0:6B:D5 master-interface=\
    wifi_5 name=IOT_5 security=IOT
add configuration=Main_2 configuration.mode=ap disabled=no mac-address=\
    7A:9A:18:F0:6B:D2 master-interface=wifi2 name=Main_2
add configuration=Main_5 configuration.mode=ap datapath=Main disabled=no \
    mac-address=7A:9A:18:F0:6B:CF master-interface=wifi_5 name=Main_5 \
    security=Main
add configuration=Management configuration.mode=ap disabled=no mac-address=\
    7A:9A:18:F0:6B:D4 master-interface=wifi2 name=Management
add name=ManagementPool ranges=192.168.99.20-192.168.99.40
add name=MainPool ranges=192.168.11.20-192.168.11.255
add name=GuestPool ranges=192.168.12.20-192.168.12.255
add name=IOTPool ranges=172.16.0.10-172.16.1.255
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=MainPool interface=MainVLAN name=Main
add address-pool=GuestPool interface=GuestVLAN name=Guest
add address-pool=IOTPool interface=IOTVLAN name=IOT
add address-pool=ManagementPool interface=ManagementVLAN name=Management
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment="Downlink Port" interface=ether2
add bridge=bridge comment=defconf interface=wifi_5
add bridge=bridge comment="Management Port" interface=ether5 pvid=99
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge tagged=ether2,bridge untagged=ether5,Management vlan-ids=99
add bridge=bridge tagged=ether2,bridge untagged=ether3,ether4,Main_5,Main_2 \
    vlan-ids=11
add bridge=bridge tagged=ether2,bridge untagged=Guest_5,Guest_2 vlan-ids=12
add bridge=bridge tagged=ether2,bridge untagged=IOT_5,IOT_2 vlan-ids=13
/interface detect-internet
set lan-interface-list=LAN wan-interface-list=WAN
add interface=ManagementVLAN list=LAN
add interface=MainVLAN list=LAN
add interface=GuestVLAN list=LAN
add interface=ether2 list=LAN
/interface wifi capsman
set ca-certificate=auto certificate=auto enabled=yes interfaces=ether2 \
    package-path="" require-peer-certificate=yes upgrade-policy=\
    require-same-version
/interface wifi provisioning
add action=none disabled=no master-configuration=Management supported-bands=\
    2ghz-ax
add address=192.168.99.1/24 interface=ManagementVLAN network=192.168.99.0
add address=192.168.11.1/24 interface=MainVLAN network=192.168.11.0
add address=192.168.12.1/24 interface=GuestVLAN network=192.168.12.0
add address=172.16.0.1 interface=IOTVLAN network=172.16.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.11.20 mac-address=E4:5F:01:DF:28:E5
add address=172.16.0.0/23 comment=IOT gateway=172.16.0.1
add address=192.168.11.0/24 comment=Main gateway=192.168.11.1
add address=192.168.12.0/24 comment=Guest gateway=192.168.12.1
add address=192.168.99.0/24 comment=Management gateway=192.168.99.1
set allow-remote-requests=yes mdns-repeat-ifaces=IOTVLAN,MainVLAN
/ip dns static
add address=192.168.88.1 comment=defconf disabled=yes name=router.lan type=A
/ip firewall address-list
add address=192.168.99.0/24 list=Management
add address=192.168.11.0/24 list=Main
add address=172.16.0.0/23 list=IOT
add address=192.168.12.0/24 list=Guest
add address=Main comment=Intra-VLAN list=IntraVLAN
add address=Guest comment=Intra-VLAN list=IntraVLAN
add address=IOT comment=Intra-VLAN list=IntraVLAN
    established,related,untracked
    invalid log=yes log-prefix="Drop Invalid Input: "
    in-interface-list=!LAN log=yes log-prefix="Drop input not from LAN: "
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=\
    "defconf: fasttrack established, firewall works on new" connection-state=\
    established,related hw-offload=yes
    "Drop packets from IOT network to the Internet" out-interface-list=WAN \
    src-address-list=IOT
    connection-state=invalid log=yes log-prefix="Drop Invalid:"
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp \
    protocol=icmp
add action=reject chain=forward comment="Drop Intra-VLAN packets" \
    dst-address-list=IntraVLAN reject-with=icmp-net-prohibited \
    src-address-list=IntraVLAN
add action=drop chain=forward comment="Drop from normal VLANs to management" \
    dst-address-list=Management src-address-list=IntraVLAN
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=\
    icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 \
    protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 \
    protocol=icmp
add action=accept chain=icmp comment=\
    "host unreachable, fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 \
    protocol=icmp
add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 \
    protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 \
    protocol=icmp
add action=drop chain=icmp comment="deny all other types"
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/London
/system identity
set name=MikroTikA
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-limit=2000KiB file-name=guestvlan.log filter-interface=GuestVLAN
You may want to add dns-server= to settings under /ip dhcp-server network explicitly. Since you don’t have them set explicitly, DHCP server might “invent” values for this property (as DHCP clients generally require it) and with automagically determined values is always potential for them to be stupid or wrong (or both).
Hi mkx, thanks for the suggestion but I checked and I could see that the device was asking for the right DNS server addresses, so it wasn’t that.
While I was looking into that though I realised what my actual mistake was:
The last three pools include the subnet broadcast address as an allocatable address. My phone (which is what I was having the issue with) had been allocated 192.168.12.255, and didn’t like being the broadcast address. I corrected the pools to end at 254 and all is well :slight_smile:
Thanks,
Mark
