I’ve got an RB600 that is pinging a list of IP addresses.
Looks like it has a bug or something. I can’t find anything. Can’t find where anyone has gotten in to it, but obviously something has happened.
Any ideas?
13:44:52 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->162.222.2.247, len 80
13:44:52 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->99.251.229.171, len 76
13:44:54 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->151.80.113.65, len 68
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->162.222.2.247, len 76
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->213.66.216.222, len 68
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->71.68.79.68, len 76
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->173.239.240.149, len 92
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->65.99.1.83, len 92
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->50.116.198.197, len 68
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->92.3.164.153, len 68
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->50.116.198.196, len 68
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->14.201.106.95, len 68
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->75.139.156.38, len 80
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->67.149.85.220, len 76
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->122.150.85.199, len 68
13:44:55 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->104.244.46.135, len 157
13:44:56 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->178.62.205.165, len 68
13:44:57 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->73.204.112.199, len 80
13:44:57 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->73.204.112.199, len 60
13:44:57 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->139.99.4.50, len 68
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->76.97.162.14, len 76
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->24.141.217.112, len 76
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->67.149.85.220, len 76
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->65.99.1.83, len 86
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->76.97.162.14, len 86
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->70.185.49.18, len 76
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->73.110.34.91, len 76
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->173.239.240.149, len 92
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->72.130.170.208, len 68
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->24.74.37.187, len 76
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->88.105.148.46, len 68
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->108.59.14.78, len 68
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->68.158.0.46, len 80
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->68.158.0.46, len 86
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->86.156.216.141, len 76
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->158.69.122.195, len 68
13:44:58 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->216.218.206.84, len 68
13:44:59 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->137.74.95.7, len 68
13:44:59 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->204.11.109.68, len 68
13:44:59 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->52.72.0.57, len 80
13:45:00 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->45.55.28.159, len 68
13:45:00 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->184.51.150.43, len 68
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->146.148.38.5, len 68
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->73.110.34.91, len 76
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->68.158.0.46, len 80
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->68.158.0.46, len 86
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->2.222.127.151, len 68
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->75.139.156.38, len 80
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->81.97.35.212, len 80
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->81.97.35.212, len 76
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->5.79.98.224, len 68
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->58.166.73.13, len 68
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->73.246.219.63, len 160
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->173.194.219.188, len 80
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->151.101.56.84, len 99
13:45:02 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->34.213.77.81, len 80
13:45:03 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->144.217.181.81, len 68
13:45:03 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->91.230.47.14, len 68
13:45:05 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->10.1.22.5, len 101
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->10.1.22.5, len 84
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->60.169.78.56, len 68
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->108.180.55.196, len 68
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->81.97.35.212, len 80
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->72.241.104.232, len 68
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->81.97.35.212, len 76
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->73.110.34.91, len 76
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->65.99.1.83, len 76
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->68.158.0.46, len 76
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->68.158.0.46, len 86
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->52.6.74.211, len 80
13:45:06 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->35.185.82.249, len 80
13:45:07 firewall,info ping - output: in:(none) out:ether2, proto ICMP (type 3, code 1), 10.1.22.2->10.1.22.5, len 88
