Odd problem
Antenna has been up and working great for 3 years.
Nasty storm and it quits, looks like the card is dead too.
Swapped card and antenna, signal went from -60s before to -80s. Figured I must have had a bad card, swapped card again, found it was the antenna. Swapped back to the original antenna, -60s. After about 12 hours, signal is -88.
Works great for a few hours then just goes to pot. Seemed like it improved after I disabled the card for a few minutes, then turned it back on.
I am swapping the antenna in a few hours, but does this sound like water in the feedhorn, cable?
Swapped a 29dBi grid to a 26dBi grid, new cable, old pigtail, new card, -55dB signal.
4 grids, 6 cables, 1 R52H, 1 R5nH, 2 R5H and we’re up and running again.
One the antennas that didn’t work is now working great on a 4 mile shot 90 degrees from the original…
Beats me.
