Offering routes via DHCP
Hi. I’m using RouterOS v 2.9.7 and I want to offer routes to other networks for clients of mikrotik’s DHCP. The primary trouble is, that all users are Windows PC, so I must use option code 249 of DHCP.
I created data with this code in my WinBOX in DHCP-Options. As far as I see from the sniffer, the option #249 is requested during DHCP request, but it isn’t returned by MT. My “option” has no effect. Any ideas?
Recently updatet to latest RouterOS but the problem remains
Im unable to get Option 33, 121 or 249 to add routes
If i add option 33 with some value I can see (via sniffer) that it is returned in DHCP responce. But it allows routing only one host which is not a solution
This is interesting issue. Can you post some option configuration example? It seems I cannot get option value right.
