Hi all.
I am trying to do like a information hotspot, but the router is not going to be connected on the internet.
What i’m trying to achieve is:
- The user connects to the Wifi,
- The captive portal intercept all traffic and Popup login page
- The page wont have any Login form, only info about schedule and some activities on a simple http web page.
- This will be oriented to mobile devices such as Phones and Tablets, but mostly phones.
The Issue:
Everything is working fine when i have a dhcp-client and the router is connected to the Internet.
If i remove internet connection, and then try to connect to the Hotspot, it wont popup any page, it only works if i open the browser and i write whatever i put on the server-profile ->dns name
if i give internet Connection to the router, everything works again.
What i have tried, i have tried this: http://forum.mikrotik.com/t/hotspot-login-redirect-page-without-internet/78594/22 without any luck.
I try to add the DNS redirection with the RegExp .* to the mikrotik IP address, but when i try to connect with my iphone, it popups a window but immediately sends an error that says something like: “too many redirects ocurrred”.
one thing i dont understand, is that if you are not logged, and the browser needs to resolve to check ifs there connection, (some say this is the cause the hotspot page wont popup), how can it check it if you are not logged in yet?..
Please help, im loosing my mind here, in short, everything works as expected when Internet Is on.. but if there is not internet at all in the router, the page wont popup..
Im using rOS 6.46.2 on a RB951Ui-2HnD
Thanks In advance.
JB
