the PTP link will be for 25KM
what is the best choice for antennas; an offset antenna or a parabolic antenna ? the feeder that is used is Interline 5Ghz feeder and in one end at 4m is a GSM tower (this I think is not good)! Please help. What would be the best choice ?
Best regards Remus
I would suggest solid parabolic for better reception and easy for the alignment..
I understand that I would do so but 2 friend of mine engineers sad that a offset antenna is more efficient, indeed is not that easy to align. and the interference what is better ? offset or parabolic ?
In our case, we choose the Pacific wireless product due to …
- Very good reputation.
- Narrow beam width.
- With 5.8Ghz antenna feed horn it can run for the 5G full range (Tested for 10KM distance).
- If interference, you can change the polarity easily.
OFFSET!!! don’t ask why!
I have tested and I confirm that a offset antenna 1,2m is more efficient and better performance, in compare with parabolic 1,5 for my link on 25KM. Thanks anyone for effort to respond to the topic
