Offtopic: HyperLink BPF2400A Bandpass Filters
This is a little bit offtopic, not exactly Mikrotik related, but I appreciate experince of members of this forum and that’s why ask about their opinion. So, is this device worth money?
If you are getting a bunch of out of band interference then yes, a 4 pole full band filter will help.
If you are trying to block inband noise, then you should get a filter for a specific channel.
The more poles a filter has, the better it will be.
I have equipment located on a hill with 7 other towers of cell phone, paging, and other equipment, Without a bandpass filter my noise floors would jump from the 60’s to 80s. After installing 8 pole channel specific filters my noise floors are now better than -100.
As usual with wireless, it all depends on your environment..
I have filters from hyperlink and rflinx in use and I haven’t noticed much difference between the two.
Hope that helps.
-Gerard
what about the ubiquiti filters you sell, I was actually just going to order one from u.. Have you used them?
I don’t use much 900mhz, but I have them on all of 900mhz AP’s I do have. They make a noticeable difference if all of your noise is out of band.
-Gerard
Hi gerard,
I tried calling u guys to make a purchase and get some info, but your 1-800 number does not work up here in Canada and the two other numbers where a NO answer. Whats your local sales phone number pls.
Thx
I’ll check into the Shoot me an e-mail at gerard at quicklinkwireless.com. You can also reach me via my WISP’s number at 502-722-9292 or on Skype quicklinkgerard..
-Gerard
