OID Active Connections
Does anyone happen to know the OID for Active Connections?
Hotspot ones? Either way, use “print oid” in the correct sub-context:
/ip hotspot active print oid
Yeah that doesn’t do the job for me. Looking for the OID for ALL active connections.
What does that mean? You want a count of how many active connections there are? AFAIK there’s no such counter. If you find a solution I’d be very interested.
ok..that’s what I wanted to know.
I thought since the OS tracks it in the firewall that there might be an OID to that number.
If there really isn’t a counter, there should be!
I am currently working around that by using a script every five minutes to log Hotspot utilization by Hotspot server. Via syslog that gets passed to an external server that then graphs the numbers:
# summarize hotspot total users via syslog
# prep string to write to log
:local message "Hotspot usage summary: ";
# step through all available hotspot servers
:foreach hotspotServer in=[/ip hotspot find] do={
# get the name of the one we're currently looking at
    :local serverName [/ip hotspot get $hotspotServer name];
    # append log string with hotspot server name and the total number of acti e users
    :set message ($message . $serverName . "=" . [/ip hotspot active print count-only where server=$serverName] . ", ");
# trim away the trailing comma and space
:set message [:pick $message 0 ([:len $message] - 2)];
# log it
:log info $message
Dirty, but it works.
Again, if you or anyone else knows a way to do this purely by SNMP that’d be very nice.
hmmm… I don’t remember where I have found it, but for ppp active session count there’s OID ‘1.3.6.1.4.1.9.9.150.1.1.1.0’
I think, there sould be something for Hotspot somewhere around…
Strange. That’s a Cisco MIB - CISCO-AAA-SESSION-MIB:casnActiveTableEntries.
Edit: it would be very helpful if Mikrotik published a current MIB file.
http://forum.mikrotik.com/t/new-features-in-2-9-11/4754/1 indicates at some point support for this was added.
http://forum.mikrotik.com/t/mikrotik-snmp-system-mibs/15951/1 claims it’s the Cisco MIB Chupaka posted, but I cannot get that to work on 4.2 (Solarwind’s Orion Custom MIB Poller reports “Device does not support this OID” when I try to query it.
I’ve emailed support asking if this is still supported, and what the OID is.
I tried the OID that Chupaka. didn’t work.
I see everyone is posting about Active Hotspot connections, this isn’t really what I was looking for.
I’m talking about the Active data Connections passing through the Firewall.
(ie…IP…Firewall…Connections) Just to clear up the confusion.
Oh. My bad. If/when I hear back from support I’ll amend the request to that OID as well. FWIW, I did a fairly thorough SNMP walk and couldn’t find a counter for either, but I’ll check again tomorrow at work to see if I can find a firewall connection one.
Support confirmed that there is no OID for the number of firewall connections tracked. It also appears that there is no OID for the number of Hotspot users active, though you can query each individual active Hotspot user.
Thanks for the heads-up, all-be-it disappointing and a bit shocking.
Granted that Active connection # bounces around alot, so trying to graph it would only reveal a rough average at best. But still that average would be nice to know. Specially when your peaking at over 500,000 active connections.
Just in case someone finds this thread via the search, support has also confirmed that there is no OID for the number of active Hotspot connections.
I feel that mt lacks snmp oid's. I hope they work on this.
I am here: http://maps.google.com/maps?ll=45.505455,-75.649082
Sent from my iPhone4 using Tapatalk
And to be confirmed as of version 6.24, there is still not oid for total-entries value of /ip firewall connection tracking.
Thats shame.
As I am currently looking for that OID, is there anything available?
