Hi all -
Iv'e the the basics working pretty well IPv4, and IPV6 thru HE tunnel.
I've got a working IPV6 firewall, but would appreciate an suggestion for improvement. ( I know it probably Sucks)
mar/18/2011 21:23:58 by RouterOS 5.0rc11
software id = SDFH-MR7B
/ipv6 firewall filter
add action=accept chain=input comment="Router - VPN Start" connection-state=new disabled=no dst-port=1723 protocol=tcp
add action=accept chain=input comment="Router - GRE Allow" disabled=no protocol=gre
add action=accept chain=input comment="Router - VPN UDP" disabled=no dst-port=1723 protocol=udp
add action=accept chain=input comment="Router - Accept established connections" connection-state=established disabled=no
add action=accept chain=input comment="Router - Accept related connections" connection-state=related disabled=no
add action=drop chain=input comment="Router - Drop invalid connections" connection-state=invalid disabled=no
add action=accept chain=input comment="Router- UDP" disabled=no protocol=udp
add action=accept chain=input comment="Router - Allow limited pings" disabled=no limit=50/5s,2 protocol=icmpv6
add action=log chain=input comment="Router - Log Excess IPv6 Pings" disabled=no log-prefix="Excess IPv6 Pings"
add action=drop chain=input comment="Router - Drop excess pings" disabled=no protocol=icmpv6
add action=accept chain=input comment="Router - From our LAN" disabled=no in-interface=ether3 src-address=2001:470:xxxx:1::/64
add action=accept chain=input comment="Router - From our WLAN1" disabled=no in-interface=wlan1 src-address=2001:470:xxxx:2::/64
add action=log chain=input comment="Router - Log everything else" disabled=no log-prefix="DROP IP6 INPUT"
add action=drop chain=input comment="Router - Drop everything else" disabled=no
add action=drop chain=forward comment="Lan - Drop invalid Connections" connection-state=invalid disabled=no
add action=accept chain=forward comment="Lan - Accept established Connections" connection-state=established disabled=no
add action=accept chain=forward comment="Lan - Accept related connections" connection-state=related disabled=no
add action=accept chain=forward comment="Lan - Accept UDP" disabled=no protocol=udp
add action=accept chain=forward comment="Lan - Allow limited pings" disabled=no limit=50/5s,2
add action=log chain=forward comment="Lan - Log excess pings" disabled=no log-prefix="Excess IPv6 pings" protocol=icmpv6
add action=drop chain=forward comment="Lan - Drop excess pings" disabled=no protocol=icmpv6
add action=accept chain=forward comment="Lan - From our Lan" disabled=no in-interface=ether3 src-address=2001:470:yyyy:1::/64
add action=accept chain=forward comment="WLan - From Wlan" disabled=no in-interface=wlan1 src-address=2001:470:yyyy:2::/64
add action=accept chain=forward comment="Lan - Accept SSH connection to mediaserver" disabled=no dst-address=
2001:470:xxxx:1:214:xxxx:5ff:fe6:792/128 dst-port=22 protocol=tcp
add action=log chain=forward comment="Lan - Log everything else" disabled=no log-prefix="Log IPv6"
add action=reject chain=forward comment="Lan - Drop everything else" connection-state=new disabled=no in-interface=sit1
Any comments helpful.
