i try to register old 802.11 Clients:
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=passthrough group-ciphers=aes-ccm group-key-update=1h interim-update=0s management-protection=allowed management-protection-key=keykeykey mode=dynamic-keys mschapv2-password="" mschapv2-username="" name=default radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=
key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=keykeykey
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=0 area="" arp=enabled arp-timeout=auto band=5ghz-a/n basic-rates-a/g=6Mbps bridge-mode=enabled channel-width=20/40mhz-eC compression=no country=germany default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=yes disable-running-check=yes disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=auto frequency-mode=manual-txpower frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=15 interworking-profile=disabled keepalive-frames=enabled l2mtu=
1600 mac-address=4C:5E:0C:45:B9:9D max-station-count=2007 mode=station-bridge mtu=1500 multicast-buffering=enabled multicast-helper=default name=wlan1 noise-floor-threshold=default nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink nv2-noise-floor-offset=default nv2-preshared-key=keykeykey nv2-qos=default
nv2-queue-count=2 nv2-security=enabled nv2-sync-secret="" on-fail-retry-time=100ms preamble-mode=both radio-name=202392-merten3 rate-selection=advanced rate-set=default rx-chains=0,1 scan-list=default,default security-profile=default ssid=ssid station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps tdma-period-size=2 tx-chains=0,1 tx-power=22 tx-power-mode=all-rates-fixed update-stats-interval=disabled vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wireless-protocol=
nv2-nstreme-802.11 wmm-support=disabled wps-mode=push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" caps-man-names="" certificate=none discovery-interfaces="" enabled=no interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
on a new arm MantBox 5Hax.
But no client will register. Is it possible?
set [ find default-name=wifi2 ] arp-timeout=auto channel.band=5ghz-n .frequency=5500 .width=20/40mhz-Ce configuration.country=Germany .mode=ap .ssid=ssid disabled=no l2mtu=1560 mac-address=F4:1E:57:2C:20:D0 name=wifi2 radio-mac=F4:1E:57:2C:20:D0 security.authentication-types=wpa2-psk .encryption=ccmp,ccmp-256 .group-encryption=ccmp
will not work, no client will register
