Old website displays when connected via mikrotik.
I know this is going to be an easy fix but it has me beat.
If I connect my laptop to the adsl modem directly www.datarite.net is displaying the new and updates site correctly.
If I connect to the mikrotic router all the websites seem to display correctly but www.datarite.net is still displaying the old website.
I have a wireless router connected to my mikrotik router v4.10
When I connect ANY web enabled device to it , it displays the old page. (iphone, laptops etc)
I have tried to reboot the router and look for cahce etc but I can’t see anything.
PLEASE HELP!!!
Thanks in advance.
Are you using the proxy? Have you flushed its cache?
When redoing the site, did DNS change and are you getting old entries?
Yes the website is on a new server and the name server was updated over 48 hours ago.
I am not using a web proxy…just mikrotik os default install…
I have looked for cache settings but have not had any luck…
I just upgraded to v4.11 but still the same result.
I know it is in the routeros as if I connect to the exact same adsl modem directly the page is correct.
It is as if the router os is still using the old name server.
So look at your name servers in both situations and ensure you’re using the same ones in both situations. Flush the DNS cache on the router, too (“/ip dns cache flush”).
ty…
That seems to have resolved the issue.
