Older SwOS not available anymore.
Hi, I was looking to download SwOS v2.7p for CRS328-24P-4S+ to downgrade from v2.9 dew to fan issues (works in v2.7p). Looks like its no longer available at https://mikrotik.com/download/archive. Does anyone have the firmware?
Thank you
Isn’t 2.7p factory version? You should be able to run it by following reinstall/reset configuration manual (http://forum.mikrotik.com/t/swos-version-2-8-released/121733/1). Since 2.7p would be > 2.7, the lowest available SwOS you can downgrade to would be 2.8 - https://download.mikrotik.com/swos2/css328p/swos-css328p-2.8.bin
@Eider, thank you for trying to help, yes 2.7p is factory. I should have mention that the CRS328 that I am trying to downgrade to 2.7 it is at a customer remote site.
Your best bet is to open support ticket with MikroTik and ask for firmware file. There is no other way to remotely go back to 2.7p.
Did that thank you for the help.
