/interface wireless> set 1 tx-power=1
value of tx-power out of range (4294967266..30)
version plz?
rc13 - changing from winbox seemingly works, however I still get -40 after setting tx-power to 0. (That’s better than -30 with default settings, but still - was better)
what interface type, chipset etc? make a supout.rif maybe?
Are you trying to tell me that I am the only one with such problem? It happens on four routers with various interfaces, some Nortels on AR5213, some DCMA-82s on AR5414. All routers have extra channels, maybe there’s something to it?
lowering TX has always worked fine, even in v3. so as far as I know - this is a specific problem.
I can bet - from winbox everything is fine
OK, confirmed. We will fix it.
lol
