greetings ..
I’m broadcasting by an Omni-Tik device to several Nanostation m5 (UBNT) ..
the distance is no more than 200 meters and there are no blocks or buildings or trees or any interference in any way ..
the Omin-Tik is a 3-5 meters higher than the station devices mentioned above ..
please take a look to the snapshots for more details in order to help me getting the best signal and CCQ ..
Thanks for your time in advance..
Regards ..
the rest of it
Poor signal levels, unsecured connection. Mixing ubnt with mikrotik is not advisable. But in your case the signal levels should be much much better. What are your actual tx values?
Use 802.11 protocol and wpa2 in security profile.
Thank you for your replay ..
your answer is accurate.
