Omnitik 5 AC. Concurrent 2.4 & 5GHz ?
Hi.
I know the Omnitik 5 (poe) AC has only a single radio - QCA9892
I read somewhere that this chip can do simultaneous 5GHz and 2.4GHz.
Is this supported in the Omnitik 5 AC ?
I am looking for a good AP for the middle of a building. This looks to have better antenna gain than the hAP AC, and same sensitivity etc.
No, Omnitik chip only supports 5GHz
Omnitik is more of an outdoor device. For your situation, hAP ac should be pretty good. You can also consider this device: https://mikrotik.com/product/RB912UAG-5HPnD-OUT
It has an extra miniPCIe slot for a second radio, plus you can use your own antennas for both radios (any gain you can find)
