OMNITIK 5 AC POE PROBLEM
Brand new, i run winbox and go to /interface ethernet poe.
Surprise! there is no POE tab, or anything about it, I look for everywhere (perhaps a change of position) but not.
I go to terminal and there is no poe section. So I can´t find the POE settings for activate or manage the POE of the Omnitik 5 AC .
I have looked for packages, but no one seems to use for that specifically. So, anyone can help me?
thanks.
Hi, are you sure, you have poe version?
https://routerboard.com/RBOmniTikG-5HacD
https://routerboard.com/RBOmniTikPG-5HacD
Well, huge mistake, seller error in description, this is not the poe version. solved.
thanks
