Hi
Does the OmniTIK 5 ac support the 4.9Ghz Superchannel?
Asking prior to purchase…
Hi
International: 5150 MHz-5875 MHz
USA: 5170-5250 MHz; 5725-5835 MHz
https://i.mt.lv/routerboard/files/OmniTIK_5_ac-171023122851.pdf
In wireless mode superchannel, you have access to range 4920-6100MHz on this device. However, since the antenna is built in, you must also bear in mind that it will not operate at peak gain, it will be lower than in normal channels.
Thanks Normis
