Hi
Have a omnitik running in 5.21 to a SXT about 750m away.
Signal is about 69/66 and ccq 35/65.
I am the only one in the site so their is no interference.
Tx-power is set to default and iam running nv2 whit tdma set to 2ms and distance 10km.
Isnt the omnitik better then this ? do I have to set up a better mimo omniantenna?
any tips?
normis
October 15, 2012, 8:38am
2
What do you consider “Bad” CCQ? did you look when traffic is running, or idle? This is important, as CCQ will change depending on traffic amount.
Hi
ccq is about 65/70 whitout any load.
When I run a bt test or torrent file the ccq drops to about 35/54. Isnt that bad ccq? I used to about 80-90-100 ccq.
normis
October 15, 2012, 8:59am
4
Please make a supout.rif file at the time when you run traffic, we will see if the problem is with config, or with environment.
I have sent one supout file to support.
I have two other links in the same tower, in freq. 5220, 5320 and the omnitik at 5745.
the picture is taken from the tower where the omnitik is mounted.
I got a serious answer from Mikrotik.
the configuration looks ok.
You can try to change the wireless frequency, maybe it is saturated and you can’t get the max speed.
But still 60Mbps is good speed and 90Mbps data-rate is good enough.
The conclusion is then that the OmniTik isn’t bettern then this if I want to push out 30Mbit of TCP data to clients.
InoX
October 16, 2012, 6:53pm
7
Everyone (almost) knows that Omnitik is very weak(small gain antenna) and will not go very far or very fast.
Well, I know it now =) hoped that it would work perfect at 1km at least?
InoX
October 16, 2012, 9:12pm
9
1km is max. you can use at a decent signal and not maximum speed.
btw you should try 5300-5600 and see what is happening.
I have already bought ubiquiti mimo 2x2 omni antenna whit rocketik. I will mount a 711G-5hnd and try it out again.
I hope that my reseller would by my omnitiks back.
I upgraded whit a ubiquiti antenna and a rf-element box. running a 711G-5HnD card.
the ccq doubled in my issue, now I have about 60-70ccq in load instead of about 30.
ugn
October 28, 2012, 12:28pm
12
gnuttisch: Can you post a link to that 711 case/box you use there?
InoX
October 28, 2012, 12:50pm
13
How hard is to search for rocketik?
ManyX
October 31, 2012, 7:21pm
15
ddd
October 31, 2012, 10:10pm
16
Did you do a spectrum scan to see if there was interference on the channel you were using?
You should be able to achieve good speeds up to 3-5km proving there is no other usage on your channel.
If read at top I wrote that I’m the only one in the site. their for I can plan the frequencies.
ddd
November 1, 2012, 9:25pm
18
The Omnitik has a omni antenna - It will pick up interference from everywhere. You need to make sure you have a selected a clean frequency.
Yes, I have already check that. The site runs much better now when I changed the antenna.
brainy
November 5, 2012, 10:11am
20
Try to disable MCS 13,14,15
i have several installations where disabling them gives ccq of 100% .. with using them the ccq is going from 30 to 80%
