Is there any way to enable DFS channels on the Omnitik AC?
should mention ‘US’ model. Seems like the DFS bits are available but doesn’t want to enable them.
You can’t, unless you get the International version or do some trickery with an EEPROM on the circuit board inside.
just trying to bump this one up.
Uses the same chipset as the mANT series that does have DFS support. I really like the omnitik ac but not having DFS channels kills it’s value for me.
Hopefully this in on the way.
Anyone from mikrotik care to comment?
are us model?
upgrading to 6.47.6 and later enable dfs channels (but NOT disable DFS check) on netmetal, i do not know if enable also on omnitik
Yes, US models.
