Omnitik AC equivalent
I would like to replace my Omnitik for something equivalent in AC. That is, 360, double poralizacion.
But Mikrotik not have this version. There will be an AC Omnitik version soon?
Can you advise me some idea to a Omnitik equivalent for change it?
Thank’s
You could always build one using routerboard and components.
Several Mikrotik vendors have their own custom solutions like these, so you might go shop some of their sites.
A omnitik is a great antenna, i have currently 260 of them in production .
at the moment there is for me no need to have a AC version, first i need to upgrade some links to AC for that
i use omnitik only for routing , client access and backup link.
Thanks for your response.
I agree with you. In fact I do not need an equivalent. My problem is the 2-3 seconds cuts between Omnitik and all SXT clients every few minutes (seconds some times). I don’t know how to solve the problem … and I am desperate.
I changed the hardware, I tried with all frequencies, etc. and I can not solve.
I thought maybe another model equivalent antenna does not have that problem, because I don’t have this problem with SXT SA5
Do you not have this problem in yours omnitiks??
