Hi everybody,
I’m trying to understand how this feature work…
We have some OmniTIK UPA-5HnD and we want to connect some other RB (750 and/or SXT) to PoE out ether ports.
Fist of all I’ve upgraded OmniTIK from 5.8 to 5.15 because in winbox the “PoE Out” option was not present.
After OmniTIK reboot the connected SXT (connected on port 4) has been powered up, but the “PoE Out” option on ethernet 4 was “off”.
I’ve plugged the same SXT on eth port 5 but it doesn’t get power. I’ve change the “PoE Out” option from off to on or auto, but nothing happened. Same thing on the other eth (2, 3). Magically, on eth4 PoE out works despite the “PoE Out” option (doesn’t matter if is on or off or auto… It works).
After some attempts I’ve been able to use PoE on every port (I had to unplug the power to OmniTIK), but how the “red light” on the back works?
With 1 PoE device connected (always the same SXT):
connected to port 2 - port 2 green, port 5 red
connected to port 3 - port 3 green, port 4 red
connected to port 4 - port 4 green and red (I think this one is the correct option)
connected to port 5 - port 5 green, port 2 red
Can please some one explain me if this behavior is ok?
Thanks everybody!
