OmniTIK is a weatherproof outdoor AP with dual-polarized omni antennas - the perfect companion for our SXT, or for any other 802.11 standard device.
Weatherproof, durable and ready to use. It has five 10/100 Ethernet ports, PoE support and a built-in 400mW 802.11a/n wireless radio. It supports Nv2 TDMA technology with up to 200Mbit aggregate throughput.
LED signal indicators on it’s back are fully customizable, show Ethernet activity or wireless signal - or any other information from RouterOS. The USB port gives the ability to connect a 3G modem or a storage drive. The OmniTIK runs RouterOS with all it’s features. Suggested price at distributors: $119http://routerboard.com/OmniTIKU-5HnD
RB711-2Hn
The RB711 is a small CPE type RouterBOARD wireless router with an
integrated 2GHz 802.11b/g/n wireless card. RB711 includes RouterOS - the operating system, which can be a router, firewall, bandwidth manager, a CPE and more - all at the same time. This device has one MMCX connector, allowing single chain connectivity. The integrated wireless card is capable of up to 27dBm transmit power output. Built in 16kV ESD protection on RF port. Suggested price at distributors: $45http://routerboard.com/RB711-2Hn
I was honestly hoping for the Omnitik with a 2 GHz solution.
Normis, If SXT is the target CPE(SU) for Omnitik why just the 7dbi Antenna??
Should 7 dbi be good enough for 3 km PtmP links?? I would like Mikrotik’s take on that.
I think that Omnitik will serve well in PtMP scenarios.
But one Ethernet port would have been sufficient.
If Ports 2 to 5 would also be able to output PoE,
then we could feed the omnitik with up to four backbone links
using only ONE cable (for power and data) to the roof of the tower.
The Omnitik would then also serve as the towers router.
But maybe the Omnitik got a nice PCB-layout like the RB750
in order to modify it for PoE-out on ports 2 to 5.
If anyone has high resolution images of the PCBs front and back,
show them here, please.
Well, ok, it is a nice toy: i think 2.4ghz version is useful in some little works, but i’m also worried about this way.
Today wisp’s business needs devices level “carrier class”, not toys.
I would like it to be a 120degree sector. This would triple the gain
and does make sense for wallmounting. But for small sites with 1-2km
radius omnitik is a good product. There are not much H-pol omnis
out there. I’m wondering how good it works with 50sxts connected.
So lets see how it performs.
I real need this product to expand my wireless. As the cost suggests, it is nice to use in micro cell - a targeted area. With NV2 and low power the device can be used with solar power that comes with small solar panels.
Depends on a huge number of factors. Including Oversubscribtion ratio, bandwidth limits, usage requirements, frequency availability. Interference, adjacent
channel spacing, antenna placement, total cost path analysis. Many things.
10? For sure if you know what you’re doing.
50? i don’t think its design implementation includes this large of CPE’s in its scope. But of course, theoretically possible.
If you want a 120 Degree sector here is your integrated Mikrotik solution:
